mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on
Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762
Owncloud for ARM (Duo/NV+ v2): http://www.readynas.com/forum/viewtopic.php?f=147&t=64597
Owncloud for x86 (NVX/Ultra/Ultra Plus/Pro): http://www.readynas.com/forum/viewtopic.php?f=48&t=64596
Continues from http://www.readynas.com/forum/viewtopic.php?f=61&t=62063
- BTS1AspirantHi again,
just a readyNAS noob here. I installed Whocares? php5 and Owncloud 4.0.7 add-on's. (including ssh, apt, bzip, etc...) all went well. Well, maybe not, I did do a "apt-get install libapache2-mod-php5" in there which prob caused me to have to isntall Whocares? php5 add-on twice. Oh well. all was working fine.
Then I went to upgrade to owncloud 4.5 so I followed slobberbones instructions with the extra precaution of going first to 4.0.15 (this went fine)
however, 4.5.11 installed fine but now when I hit the owncloud site https://x.x.x.x/owncloud I get a mal-formatted version of the owncloud page. (The owncloud login page looks fine, I enter admin/netgear1 and then I get the weird page.
Any thoughts?
thanks! - BTS1AspirantSorry for the waste of bandwidth. After multiple reinstalls, I have 4.5.5 running...don't know if 4.5.11 will work here yet...
- pugilaresAspirantDid you try with 5 series?
- BTS1AspirantI did not try v5 based on fastfwd's post above citing current bugs. Any other experiences?
- fastfwdVirtuoso
BTS wrote: I assume that this is a typo in slobberbones update instructions:
cp -Rn ../owncloud_save/apps/ ./
since there is no "-n" option for cp...
The GNU version of cp accepts the -n option; it means "do not overwrite existing files". Slobberbone used it on that line to prevent the script from erroneously overwriting updated versions of built-in apps with the older versions from your previous installation. - BTS1AspirantThanks for the clarification! didn't realize Gnu and Debian were running different versions of cp...
- rklosinskiAspirantIm trying to upgrade owncloud on a Duo v2 but cannot figure out how to get bzip2. apt-cache list does not show it listed! HELP!
- rklosinskiAspirantDuh! nvmd. apt-get update fixed that problem!
- christi1AspirantHi
I have been trying to manually install owncloud 5 on my NV+ v2 (arm). I can get this to work with the exception of user authentication. There's a suggestion on the owncloud forums that this is because the frontview apache install uses authtype basic authentication, which interferes with owncloud's own authentication. Adding "Satisfy Any" to the apache config for the owncloud directory as suggested there doesn't seem to help.
Does anyone know the correct way to configure frontview apache to enable owncloud to work multi-user?
Thanks. - nieldmAspirantCan anyone tell me how to configure owncloud on a ReadyNAS Duo to use the USB attached hard drive? I want to attach a 1TB USB disk and use that for the cloud, leaving my main storage (used for Time Machine) untouched.
I can't see anything obvious in the settings.....
Guidance appreciated!
