mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on
Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762
Owncloud for ARM (Duo/NV+ v2): http://www.readynas.com/forum/viewtopic.php?f=147&t=64597
Owncloud for x86 (NVX/Ultra/Ultra Plus/Pro): http://www.readynas.com/forum/viewtopic.php?f=48&t=64596
Continues from http://www.readynas.com/forum/viewtopic.php?f=61&t=62063
- beniroquaiAspirantIf anybody is interested: It's possible to install owncloud on the new OS6 version. Just install the wordpress, PHP and MySQL package. Finally you can use the script provided in the earlier posts here. I did it as the following:
Create a MySQL-Database for Example:
----------------------------------------------------------------------------Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> CREATE DATABASE owncloud;
Query OK, 1 row affected (0.00 sec)
mysql> GRANT ALL PRIVILEGES ON owncloud.* TO "owncloud"@"localhost"
-> IDENTIFIED BY "password";
Query OK, 0 rows affected (0.00 sec)
mysql> FLUSH PRIVILEGES;
Query OK, 0 rows affected (0.01 sec)
mysql> EXIT
Bye
Then install owncloud:cd /tmp
wget http://download.owncloud.org/community/owncloud-5.0.6.tar.bz2
tar -xjf owncloud-5.0.6.tar.bz2
mv owncloud /apps/wordpress/web
chown -R admin:admin /apps/wordpressweb
Then go to you browser and finish the installation routine. It's working perfectly! Htaccess might be tricky. Any suggestion how to handle it? - fastfwdVirtuoso
nieldm wrote: Can anyone tell me how to configure owncloud on a ReadyNAS Duo to use the USB attached hard drive? I want to attach a 1TB USB disk and use that for the cloud, leaving my main storage (used for Time Machine) untouched.
In your owncloud directory, there's probably a "data" directory already symlinked to something like /c/.owncloud/data/ . Change that symlink to point at a directory on your USB drive instead (and set the ownership and permissions on that new directory to match the ownership/permissions of the /c/.owncloud/data/ directory), then restart your webserver. - WSJTutorI'm currently running OwnCloud 5.0.5 on my Duo - and it works fine.
I've tried to update to 5.0.8 but that's causing the following "Fatal PHP" error:xcache_clear_cache(): xcache.admin.user and/or xcache.admin.pass settings is not configured. Make sure you've modified the correct php ini file for your php used in webserver. at /usr/share/owncloud/lib/util.php#853
Did anyone experience the same and managed to fix it?
ReadyNAS Duo (v1) with RAIDiator 4.1.12
PHP Version 5.3.17-0rnx1
XCache Version 2.0.1
xcache.admin.enable_auth = On
http://forum.owncloud.org/viewtopic.php?f=23&t=13382 makes me believe that 5.0.8 is buggy - should better wait for 5.0.9 - MontyJAspirantI just installed the only available OwnCloud version I saw that was available through the add-ons on the Netgear site. However, the 4.0.4 version is about a year old, and a newer one for ARM is available, 4.0.16, according to OwnCloud support.
Is there install manager for that version, ie is there a .bin file I can download and install over the current year old version? OwnCloud said I could do a manual install, but not sure how to go about that on the ReadyNAS Duo V2.
Anyone have a link for the newer file, or a procedure I can use to manually install the newer version into the Duo?
Thanks!
Montyj - fastfwdVirtuoso
MontyJ wrote: Anyone have a link for the newer file, or a procedure I can use to manually install the newer version into the Duo?
See the answer I just posted to your question on the Owncloud forum:
https://forum.owncloud.org/viewtopic.php?f=3&t=13566&p=35171#p35171 - slobberboneAspirantHye all, on this page, you've got in comment multiple steps to pass to 5 owncloud's version : http://www.slobberbone.net/dotclear/ind ... as-Ultra-4
Good luck ! - beniroquaiAspirantOne quick question: Is there a guide on how to install the owncloud without the addon? ;) THank you for the upgrade guide anyway!! :)
- slobberboneAspirantHye all !
I've update my owncloud instance from 5.0.7 to 5.0.10 and I've a problem, Error 500, it's because xcache is not configured.
You have to edit /etc/php5/apache2/conf.d/xcache.ini
And configure it like :[xcache.admin]
; Configure this to use admin pages
xcache.admin.user = "admin"
; xcache.admin.pass = md5(thepasswordwithoutMD5encryption)
xcache.admin.pass = "thepasswordwithMD5encryption"
You can use this page to encrypt directly in md5 : http://www.md5.fr/ or try comment the last line and uncomment this one ; xcache.admin.pass = md5(thepasswordwithoutMD5encryption)
After that, I've got a problem of redirection ... again ... - slobberboneAspirant
I closed my web browser and reopen it, and Owncloud works like a charm ! - herko1AspirantI have an Ultra 4 with RAIDiator (latest). Is there some way to install OwnCloud 5 on my machine, or someone willing to explain how to do this? Any help is greatly appreciated (also because the readnasxtra's site has crashed and the owncloud addon has vanished from the interwebs).
