chapo
Apr 07, 2019Aspirant
PhpMyAdmin & MysqlOn Addons (Sparc)
Hello, I'm setting up an old NV+ as a personal webserver for learning/experimenting at
https://redheadedstepchild.duckdns.org:4552/www/
. So far I set up automatic ddns updates with duckdns and ...
- Apr 07, 2019
chapo wrote:
Do I still need the MySqlOn add-on?
Yes if you want to enable mysql. You can find it here: http://www.readynas.com/contributed/super-poussin/MysqlOn_1.0.bin
The SQL package on the NV+ is quite old - not sure if it can be updated or not.
chapo
I also require the php 5.4.x addon.
- StephenBApr 07, 2019Guru - Experienced User
I recommend purchasing it from: https://rnxtras.com/readynas-os4-sparc
Inexpensive, and WhoCares_ provides support.
- chapoApr 07, 2019Aspirant
Thank you, I got the php5 & phpmyadmin bundle from whocares. Do I still need the MySqlOn add-on?
