pasglop
Dec 10, 2010Aspirant
phpmyadmin add-on which username and password ?
Hi Sorry , I didn't find the answer to this , I am using : ReadyNas NVX Raidator 4.2.15 MysqlOn 1.0 PHP5GD by superpoussin v1.1 PHPMyAdmin 2.3 When I click on Launch PhpmyAdmin I have a Bie...
RezzZ
Oct 03, 2011Tutor
Hi Stefan, thank you for your reply.
I installed the MysqlOn addon, changed the socket like you said and the allowemptypasswords was allready checked. It works now!
I tried enabling ssl but that doesn't seem to work.
Perhaps this instruction should be added to the configuration instruction that comes with the addon...
