Papagaiou
Oct 05, 2012Aspirant
phpMyAdmin complains about mcrypt not being installed
Hello, I noticed that phpMyAdmin (from WhoCares) complains that mcrypt is missing (from PHP addon of WHocares) I cannot fixed with apt-get because the dependency are not the same. Also what i...
mdgm-ntgr
Oct 05, 2012NETGEAR Employee Retired
What model ReadyNAS is this?
What version of the PHP add-on?
What version of the PHPMyAdmin add-on?
Have you checked to make sure the mcrypt module is enabled in the PHP add-on configuration (e.g. in Frontview under Add-ons > Installed > PHP5 if this is on your Ultra)? If it's not enabled it, enable it (don't forget to click Apply).
