Papagaiou
Oct 05, 2012Aspirant
phpMyAdmin complains about mcrypt not being installed
Hello, I noticed that phpMyAdmin (from WhoCares) complains that mcrypt is missing (from PHP addon of WHocares) I cannot fixed with apt-get because the dependency are not the same. Also what i...
Papagaiou
What model ReadyNAS is this?
Ultra 2 running 4.2.22
What version of the PHP add-on?
PHP5_5.3.14-rnx86-4.2.1
What version of the PHPMyAdmin add-on?
PRO-PHPMyAdmin_2.5
Have you checked to make sure the mcrypt module is enabled in the PHP add-on configuration (e.g. in Frontview under Add-ons > Installed > PHP5 if this is on your Ultra)? If it's not enabled it, enable it (don't forget to click Apply)
Yes it is enabled.
PRO-PHPMyAdmin_2.5
Yes it is enabled.
