panosnl's avatar
panosnl
PureFTPd addon not installing
Hi,
I just bought and downloaded the PureFTPd add-on ( http://www.readynas.com/forum/viewtopic.php?f=48&t=52769)
I read that :
This module requires PHP with SQLite3 support to be installed
I think I have PHP with SQLite3 installed since my phpinfo() states:
pdo_sqlite
PDO Driver for SQLite 3.x enabled
PECL Module version 1.0.1 $Id: pdo_sqlite.c,v 1.10.2.6 2006/01/01 12:50:12 sniper Exp $
SQLite Library 3.7.5
Still I get the error:
The PHP add-on must be installed for this add-on to work. Please install the PHP add-on from http://readynasfreeware.org first.
[Thu Oct 6 14:20:37 CEST 2011]
It seems that there is not a check on PHP with SQLite3 but instead on the addon for this. If this is true, I would be very disappointed since this is not mentioned in the prerequisites.
Any help would be appreciated..
thx
1 Reply
    I just checked the code and it does neither ;) Actually it uses a very outdated method to determine whether any PHP is installed and I think that you're right in thinking that this should be fixed. It would be helpful if you'd forward this to info@readynasxtras.com because the folks who are reading that account don't normally scan the forums here and I'm on the road and can't do much to fix this in a reasonable time frame.
    -Stefan
ProSupport for Business
