ajwh1
Jun 10, 2018Aspirant
RAIDar 6-3 not working on NV+
Running Win10pro.
the newtork shows the shares on my NV+, and I can login to the admin page using Firefox and the TCPIP address but RAIDar looks for an attached device then closes.
Network ->...
- Jun 18, 2018
Problem solved!
I won't detail all the steps it took me to get there, but apparently RAIDar 6-3 needs Java.
Once I updated my Java to the latest version (with all sorts of security warnings) RAIDar 6-3 works.
ajwh1
Jun 12, 2018Aspirant
AHA - a bit more info: If I try to log in using EDGE I get a warning:
This site is not secureThis might mean that someone’s trying to trick you or steal any information that you send to the server. You should close this site immediately.
Your PC doesn’t trust this website’s security certificate. Error Code: DLG_FLAGS_INVALID_CA
Would RAIDar check a security certificate?
I remember that I had to add an exception to FFx because the certificate was insecure.
Jun 12, 2018Guru - Experienced User
AFAIK RAIDar won't give you any certificate warnings. With Edge, Chrome, etc you need to click through them (the "add security exception" feature is unique to FireFox).
Are you getting the RAIDar error with "browse" or with "setup"?
If you are connecting over WiFi, make sure that Windows is classifying the network as "private".
- ajwh1Jun 18, 2018Aspirant
Problem solved!
