ajwh1
Jun 10, 2018Aspirant
RAIDar 6-3 not working on NV+
Running Win10pro.
the newtork shows the shares on my NV+, and I can login to the admin page using Firefox and the TCPIP address but RAIDar looks for an attached device then closes.
Network ->...
- Jun 18, 2018
Problem solved!
I won't detail all the steps it took me to get there, but apparently RAIDar 6-3 needs Java.
Once I updated my Java to the latest version (with all sorts of security warnings) RAIDar 6-3 works.
Jun 12, 2018Guru - Experienced User
AFAIK RAIDar won't give you any certificate warnings. With Edge, Chrome, etc you need to click through them (the "add security exception" feature is unique to FireFox).
Are you getting the RAIDar error with "browse" or with "setup"?
If you are connecting over WiFi, make sure that Windows is classifying the network as "private".
ajwh1
Jun 18, 2018Aspirant
Problem solved!
