guysmithuk
Apr 20, 2026Aspirant
Swapping disks from failed unit
hi i i have a readynas duo v2 with 2 raid drives the unit has failed suddenly- the light flashes regardless of one or two or no drives so i think its a dead unit. i have brought a new unit of the ...
- May 10, 2026
All sorted now thanks.
new ( old) unit works well.
thank you
guysmithuk
thanks for the reply.
definitely v2!as it’s on the front panel
and yes - the unit i’m getting is second hand.
by scratch disk do you mean a new hard drive?
once i have done this and it boots with a new disk- do i try disk 1 or 2 from the old machine first?
guy
Sandshark
Apr 28, 2026Sensei
I hope you verified the replacement unit is also REALLY a V2. There are a LOT of "V2" units for sale that are not, for the reason StephenB explained. If the replacement is not a real V2, DO NOT put your drives in it, they will be re-formatted. But the V1 and V2 power supplies are compatible with each other, so you can still try that.
