Rob_Brown
Apr 26, 2019Tutor
ReadyNas & ReadyCloud
Hi community,
The company I work for has a pair of Netgear's RNDP6000 ReadyNAS Pro 6's.
They've not been properly utilised in the past and I'm looking to have them in service for backups. 1 a...
- Apr 26, 2019
Hi Rob_Brown,
Welcome to the Community!
ReadyCLOUD cannot detect your ReadyNAS Pro 6 because only the ReadyNAS devices that have OS6 firmware can use the ReadyCLOUD feature.
You can set up a VPN on your network as a workaround.
Another option is to convert your ReadyNAS Pro 6 firmware to OS6 but NETGEAR does not recommend or support this procedure. You may check this thread regarding this.
JohnCM_S
Apr 26, 2019NETGEAR Employee Retired
Hi Rob_Brown,
Rob_Brown
Apr 30, 2019Tutor
That's worked just fine. The unit upgraded without any apparent issue.
Had a bit of head scratching when the default password was different after the update. Might be worth adding a spot of clarity to the thread to confirm the different default password?
Many thanks.
