Ohmarr
Jun 14, 2023Aspirant
ReadyNAS 10400 Stuck at Password Recovery
Hi Community, hoping someone can help with my out of support device. Rebooted my ReadyNAS RN10400 after resolving some home network issues and it is now stuck at the password recovery screen. I e...
Jun 14, 2023Guru - Experienced User
Ohmarr: In addition to resetting the password and network configuration, the OS reinstall will also turn off volume quota. You can re-enable that on the volume settings wheel.
Sandshark
Jun 14, 2023Sensei
It sounds to me like you saved the old password in your browser and it's sending that to the NAS. Of course, it's wrong, so the NAS thinks you need to reset it.
