Ohmarr
Jun 13, 2023Aspirant
ReadyNAS 10400 Stuck at Password Recovery
Hi Community, hoping someone can help with my out of support device. Rebooted my ReadyNAS RN10400 after resolving some home network issues and it is now stuck at the password recovery screen. I e...
Jun 16, 2023Guru - Experienced User
Ohmarr wrote:
In positive news I am now able to browse the shares. When prompted I used this password: http://clusterfrak.com/kb/appliance_kb/readynas_recovery/
That password is only for tech support mode, which you are not using. You are ending up with "guest" mode access for the shares (I confirmed that on my own RN102).
Ohmarr wrote:
Anyone know why the OS reinstall is not working? Runs through it but always dumps me back at the Password Recovery screen with my security question so clearly has not re-installed the OS.
It should have worked so this isn't clear what's going on. Have you tried a browser on another device (PC, phone, tablet)??? It's conceivable you have a full root - were there any indications of that before the problem occured? What apps are installed (if any)?
As an aside, IMO it is reasonably safe to note the admin password on the door inside the NAS, People who have physical access can do the reinstall, or just take the disks and do file system recovery on another system - so they can get to your files w/o the admin password. Just my view, others would disagree.
If you are comfortable with the linux command line, it would be possible to use tech support mode, and manually mount the OS partition. That would enable more troubleshooting. You could alternatively do a factory default after you off-load the data - then reconfigure the NAS, and restore the data from your backup.
Ohmarr
Jun 17, 2023Aspirant
I have sourced another NAS, going to replicate the data and then factory reset.
Thanks for all the suggestions, appreciate the support.
This is for my home so not that concerned about the security stuff.
- shuvamJun 25, 2023Aspirant
I have a ReadyNAS 10200 (2-bay, no drives) which I have been using for a few years. I have the same problem with password recovery. I have done password recovery before, a couple of years ago, and the system sends out an email with the new password. This time, the wait-cursor is spinning forever once I click the "Recover" button.
I'm using Firefox and Chrome on Ubuntu Linux. On both the browsers, the endless-spinning wait-cursor is the same. Note that it does not tell me that the recovery details are incorrect. It just goes on spinning.
I had enabled SSH access when I had set up the NAS. I had created a user account for myself, and enabled SSH account for that account. Since I had set up SSHd and had installed a key, I don't need to know my password to log in using SSH. This SSH still works. I can log in, poke around in the system, and the system seems healthy. This account does not seem to be able to do "su" to become root -- I get an authentication failure when I run "su".
Is there any way by which I can reset the admin password from the shell prompt without becoming root?
- SandsharkJun 25, 2023Sensei
What email service are you using? Do you have it set up to send any alerts, and have you been getting them? Some providers (Gmail is one) changed the method needed to log in. If you did not make the necessary changes, then that could be your problem.
It is a bad idea to make password changes "behind the scenes" via SSH. The better way is to do an OS re-install (making sure you don't accidently do a factory default, which will wipe your volume), which will reset the admin password back to the default of password.
P.S. In the future, please do not "tack on" your question to someone else's. Start a new thread unless your question is exactly like the original poster's.
- shuvamJun 27, 2023Aspirant
I am using Gmail. I have received alert emails from my ReadyNAS box as recently as May. Has Gmail made any changes in the last 2 months?
And I "tacked on" my question to someone else's because my question is EXACTLY like the original poster's, IMHO. I also saw that interest in his question died down because he decided to bite the bullet and replace his entire NAS device, though he received no explanation which actually solved his problem. Therefore I felt that if others "tack on" their very similar reports to this, it may gain more attention. I have seen a similar situation several months ago, when the ReadyNAS firmware was failing to download anti-virus signature databases from the server for lots of us (including me). It later got solved for most of us due to some update to the firmware, even though no such clear acknowledgment came from the Netgear firmware team. I'm hoping that some similar fix will come for our problem too.
- StephenBJun 27, 2023Guru - Experienced User
Are you using an app-specific password on the NAS?
Are you also unable to log into the NAS web ui?
- shuvamJul 03, 2023Aspirant
I am using my own Gmail password on the NAS, the one I normally use to log into the Gmail browser interface.
And yes, the whole password recovery journey started because I too am unable to log into the admin interface with the browser. And I haven't "lost" my password -- I keep such passwords written in a password store, since they are not guessable. So it's very unlikely I'm typing in some wrong password.
- StephenBJul 03, 2023Guru - Experienced User
Ok. Though that just means you reused the gmail password with the NAS admin account.
But you said also that you were no longer getting email alerts in your gmail. That's configured in a different part of the NAS web ui. And you need to change that password over to an app-specific google password to get email alerts.
Back to the main problem - the OS reinstall will definitely reset the admin password back to password.
Make sure you are browsing to https://nas-ip-address/admin, and also try incognito browsing to be certain the browser isn't auto-filling the wrong password.
