ACrescendo's avatar
ACrescendo
Readynas duo v1 Access Problem because of user rights failure
Hello,
I was adjusting some file owner rights on readynas duo with ssh connection.Mistakenly, ı have assigned a predefined user to all files as owner while ı am at the root. That messed the things, and now ı cannot connect to web interface and make ssh connection. I need to access my files , they are valuable. So ı was thinking to remove all disks from nas device, then making a factory reset, then inserting the disks back? Does it work? or what is the true way of managing the getting the files? Raidar ticks green for 2 disks and can browse the file directory but cannot access.
Thanks in advance...
  • StephenB's avatar
    No, it will not.  The factory reset formats the disks, and install linux and the ReadyNAS app on them.  It cannot be done diskless.
    Try using R-linux on a Windows
    Power down the NAS and connect disk 1 to the PC via either SATA or a USB adapter/dock.  If you don't see the files, try again with disk 2 (on a Duo v1, the mirror is formatted a bit differently from the primary disk).
    Best to label t
    • ACrescendo's avatar
      ACrescendo
      So, when ı remove disks, I should be sure that disks can be read by another software. Does raid mechanism break things?
      • StephenB's avatar
        R-Linux (free) should work, assuming the Duo is using RAID-1/X-RAID or JBOD (two volumes, one on each disk).  It only reads the disk, so everything on it remains intact even if you find it isn't working.
        If you are using RAID-0 (one volume with no RAID redundancy) then you would need to use R-Studio (which is not free), or a similar product that supports RAID recovery and the EXT file system.
  • Have you tried an OS re-install?  That should reset the rights to all the OS partition files and I would expect that to allow you to log in.  I don't recall on a V1 whether an OS re-install then requires you to re-enable SSH.
    Even if you had not made that mistake, messing with user permissions via SSH is a really bad idea.  The ReadyNAS also maintains it's own databases, and making changes like that could create issues when the Linux permissions don't jive with what the database thinks they should be.
      ACrescendo
      Os-reinstall , even with usb, didnt work, nothing happened. So ı will go with the Stephen B.'s solution, and check it works or not.
ProSupport for Business
