ElChisellero
Apr 08, 2024Aspirant
Readynas Duo v2 status Not-redundant
I'm using a very old ReadyNas Duo v2 which I set up as a redundant pair of disks. However, I have just noticed it is now reporting a status of "Volume C: RAID Level X2, not Redundant. A disk failure will render this volume dead.; 1023 GB (55%) of 1841 GB used"
Both disks are reported as functioning normally.
I'm not sure when or why this happened, since it stopped sending alert emails a while ago.
I can't find anything online to advise on what I can do about this or how to set it back to redundant. Can anybody help please?
Is the array syncing?
What firmware is the NAS running?
- ElChiselleroAspirant
How can I tell if it's syncing?
Firmware is 5.3.13
Thanks
"Syncing" is re-creating the RAID-1 mirroring - copying the contents of one drive onto the other. If the volume is degraded and NOT syncing, then something is really wrong - generally a failed disk (despite the status you are seeing).
The dashboard should tell you if the NAS is syncing. I'm not sure where though, as I've never owned a v2 ReadyNAS (though I do have other models).
RAIDar will also tell you (one of the disk icons will be blinking).
I suggest downloading the full log zip file from the dashboard. There is a lot of information in there (much more than the web interface shows). If you need help analyzing it, let us know.
If you do not have a backup of the files, then you should make one right away.
