SpencerMKE
Oct 06, 2022Follower
Readynas Failed Raid with iScsi
I have a Reaynas Pro 6 with a failed array after a firmware update. I was able to extract out the c.c.dsk image from the raid, good thing it wasn't corrupt, just broken in the readynas software. My issue is that I have two iSCSI LUNs on this. is there a method to open up these images? or some type of recovery I can do on the readynas and force the raid array online?
THanks.
Spencer
- SamirDProdigy
It's a long shot, but I would try removing the drive from the readynas and put them in a regular system and boot up a linux live cd and see if you can recover them that way.
Not sure if you are still facing this issue or not. But if the array is simply out of sync, you can boot the NAS in tech support mode, and manually force it to assemble.
