JasonCP
Dec 14, 2020Aspirant
ReadyNAS front view backing up jobs
Dear community,
Having just found out the my newly purchased ReadyNAS DuoV2, is actually a V1 (Ebay purchase), I have pursued with it and loaded RAIDiator 4.1.8, so far so good. I have read the downloaded manual (RAIDiator4-1_SW_en_06Dec11) and still feel that I am doing something wrong.
I have also started to use ReadyNAS Vault.
I have created seven shares.
I have also created five backup jobs and set them off, albeit they show completed – I notice that there is no change to the Volume capacity of my RedayNAS (542MB of 1846GB), which is the same before this was done.
The readyNAS Vault is showing 91.53MB of the free 2.00GB used.
I am totally confused and am sure that I have set something up wrong on the ReadyNAS front view software, any assistance from you guys would be so much appreciated as I am tearing my hair out.
Thanking you all in advance.
Current firmware is 4.1.16, and you should be using that. https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
Maybe reach out to vault support. You can try sending an email to [email protected]. You could also submit a request via their help desk link: https://support.readynasvault.com
- JasonCPAspirant
Many thanks for your help StephenB, I will download and install 4.1.16 Sparc. If the problem persists, I'll email the support team.
Thank-you again.
