JasonCP
Dec 14, 2020Aspirant
ReadyNAS front view backing up jobs
Dear community, Having just found out the my newly purchased ReadyNAS DuoV2, is actually a V1 (Ebay purchase), I have pursued with it and loaded RAIDiator 4.1.8, so far so good. I have read the down...
- Dec 15, 2020
Current firmware is 4.1.16, and you should be using that. https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
JasonCP wrote:
I notice that there is no change to the Volume capacity of my RedayNAS (542MB of 1846GB), which is the same before this was done.
The readyNAS Vault is showing 91.53MB of the free 2.00GB used.
Maybe reach out to vault support. You can try sending an email to [email protected]. You could also submit a request via their help desk link: https://support.readynasvault.com
Dec 15, 2020Guru - Experienced User
- JasonCPDec 15, 2020Aspirant
Many thanks for your help StephenB, I will download and install 4.1.16 Sparc. If the problem persists, I'll email the support team.
Thank-you again.
