yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
yoh-dah
Apr 19, 2008Guide
You shouldn't need to mess with your router. Photos are only shared to the folks you invite, so these folks can always see the album you had shared unless you remove the shared album. You can find out more info here if you haven't already looked.
With regard to it not working, try getting the latest add-on image from here and re-install the add-on.
