yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
k_3po
May 29, 2008Aspirant
CuriousMind wrote: Hi, just got my ReadyNAS Due installed today and are having some problems with the ReadNAS Photos
The unit came preinstalled with version 1.1 which I have now updated to 1.5 from the ReadyNAS site. I now have to authenticate to ReadyNAS Photos, when before I didn't have to.
But the main problem is importing my photos. I have tried using the Import Album option, but with little success on either version. Basically I have experienced the following...
1. Initially tried to import 6Gb of photo's, basically all my photo folders, but this just hangs 5% into it
2. Then tried importing one folder at a time. On the older version this worked initially, but now although it says it is successful, there is no album displayed. Have tried logging off, stopping server, restarting service, but no display.
3. Only success I've managed todate is to manually create a new album and import photos.
Any ideas on why I cannot import my entire photo library in one go? or why my photos are being displayed? Or why I now have to login, even though the media share is set for public access?
Can you send me the desktop logs? I will PM you the instructions.
/k-3po
