yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
rfinn
Jun 19, 2008Aspirant
I imported an album and it duplicated my files.
It seems to be that most ReadyNAS users who want to share photos already store their photos on their NAS. The default behavior should be to assume the photos are already there and share them from wherever the user has stored them. An option should be added to album create/import which indicates if the photos should be copied or left in place (similar to how Adobe Lightroom allows photos to be imported into Lightroom's managed library or to be imported in their current location).
Also, when I look at my shared album and click on a photo, I get a 404 File Not Found error. So, my users cannot see the full-res version. How can I fix this? The thumbnails are shared without any problem, I use shared access, and CIFS is enabled.
