yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
Woogie
Jun 20, 2008Aspirant
minerva wrote:
rfinn wrote: I imported an album and it duplicated my files.
Photos are not cloned if you imported from some other directory in \\<nasip>\media\Pictures\.
I am running RAIDiator 4.01b1-p3-T77 (ReadyNAS Photos 1.7) with version 1.1.RC3 of the desktop software.
I copied a new album to my desired folder on the ReadyNAS and then created a new album within an existing album, and imported the pictures using "\\<ReadyNASname>\media\Pictures\<userid>\<main_album>\<sub_album>\<sub_sub_album>\<all pictures>", and the folder and all of it's contents were duplicated in my <userid> folder. I think that there should be some option to import an album within an album and/or some option to create an album and use the pictures where they have been placed on the ReadyNAS. It allows for a much more organized set of pictures.
