yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
gotztofly
Aug 21, 2008Aspirant
I keep trying to use this externally and it does not work. What ports does this thing use? I tell it the ip address of the readynas ( I am offsite at home, not on the local lan) it tells me there is not readynas device detected. I want to have the software installed at a remote location to manage the photos. I can do this from inside the network and share albums. They do recieve the link and can view the photos. How can I do what I need it to do? I beleive it is just a port forwarding issue
Thank you
Thank you
