yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
ablevy
Nov 02, 2008Aspirant
I just recently installed Version 1.1. I am trying to set up my wife to be able to run Ready NAS photos. I have her set up to log in, but when I try to create an album i get the error message " cannot create directory \\192.168.1.150\media\pictures\ellenjo\filename". When I look in pictures the directory Ellenjo is already there but empty. I get this message whether I try to add the album from her C drive or copy the files first to the NAS from her machine and then try to create the album. I also get the same answer if I try to do it under my user name from her machine. CIFS is enabled and the media share is setupu with read/write enabled.
On another note, I don't really like the way REadyNAS photos doesn't have any flexibility in the way it imports photos. I had all my photos set up as a series of directories. I really don't want them nested under user names. If we aren't going to have that flexibility under ReadyNas Photos, I will just import them manually. Under those circumstances, I don't want them duplicated to my user subdirectory under pictures.
Thanks
Alan
Thanks
Alan
