yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
Jimmy11
Jan 21, 2009Aspirant
System Error 1219 - Photos Logon Error
Hi, Thank you for this forum. I have been enjoying my ReadyNAS Photo Add-in, but have managed to mess it up so that I can not login to the NAS using the ‘Connect to ReadyNAS’ form. Here’s the error message…
“Unable to connect to ReadyNAS Photos share on 192.168.0.79
share=[hostname=192.168.0.79, share=Dekoh$, username=admin], exit code=[2], error=[System error 1219 has occurred. Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again.. ]”
I have been loging into the Photo Add-in with the NAS admin username and password. The login appears to varify. Then the error message appears.
The ‘media share’ has read/write default access, and allow guest access is checked. Prior to this, I accidently removed the add-in from the front-view, by pressing the remove button instead of unchecking it. I have successfully re-installed the add-in and the software. I am currently, using XP and version 4.1.4 of the NAS firmware.
Thank you for supporting this great program. Any help would be appreciated.
