yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
minerva
Mar 25, 2009Aspirant
User accounts you have setup on ReadyNAS NV+ do not matter in anyway to login to readynas photos.
After you login, to connect to ReadyNAS NV+ you will need to give user name, password if you have setup your ReadyNAS in share mode.
Can you try the following :
* Login at http://login.readynasphotos.com to check if the username and password you have signed up for work ? If this passes without giving any error, perhaps your PC is behind a proxy ? In this case, it will be useful to know the exact error message you are seeing.
* Please also take a look at the first post in this thread, to and verify your ReadyNAS NV+ setup.
-minerva
-minerva
