yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
shumbies
Jun 15, 2009Aspirant
Hi mullinsworld,
Check the post before mine where minerva says
Hope this helps.
Cheers
shumbies
. If you click on the hyperlink contained under the word "here", you will be taken there. I had what I think is a similar issue to you and this cured my problem.
Can you see if my reply to a previous posting here will help?
Hope this helps.
Cheers
shumbies
