yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
beck2oldschool
Jul 22, 2009Aspirant
Hi @all,
I have RAIDiator 4.1.4 and ReadyNAS Photos 2.2 installed.
At this Site: http://localhost:81/readynas/template/index.jsp?pageId=settings I click on "connect". There are several messages.
"Authentication successfully"
"Configuration of ReadyNAS will be validated..."
and after a while: "By establishing a connection a problem has occured - Connection to readynasphotos.com must be possible. For the first connection to ReadyNAS, a Internetconnection is necessary"
It is possible to connect to readynasphotos.com from my localhost. I have no deny-messages in the firewalls logfile. The right standard Gateway is set on the readynas. Also the DNS server etc. When I try to look for new firmware, the readynas connect also to the internet, so I think the connection is of course possible.
What can be the problem?
Thanks in advance!
Michael
Thanks in advance!
Michael
