yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
erlangerboys
Oct 19, 2009Aspirant
Hi, Just recently installed a readynas duo. Have enabled the photo service and downloaded the desktop software. It get around 30% of performing the install and then exits with an error suggesting delete a folder and try again. The error being generated is identical to the posting on this thread from NOTSURE of 11 Feb 2009. I have made sure that all versions of the software and firmware are as advised on this site.
Cheers
Andy
Cheers
Andy
