yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
kclark
May 15, 2010Aspirant
Can not Connect ReadyNAS Photos share exit code 32
Hello,
I have the following setup:
The webserver (http://localhost:1025/readynas/template/index.jsp?pageId=settings) finds my NAS box, but cannot connect to it.
I originally had my media/Pictures share as a symlink to /backup/machine_name/kev/Pictures, which I thought may have been causing the problem. So I moved this to 'Pictures2', and created a new folder 'Pictures' under media, with full permissions. Yet when I try to connect I get the same error. I have tried using with and without authentication (using my NAS local account and using the root account), but same result.
Here is the full error:
Any pointers would be grateful.
Thanks,
Kevin
Hello,
- ReadyNAS Duo
RAIDiator 4.1.6 [1.00a043]
ReadyNas Photos Service v2.2 (Service installed and enabled)
ReadyNas Photos application 1.1 for Linux (icon is shown in Notification area)
media share has full read/write access over CIFS, NFS and FTP
CIFS has 'Allow guest' enabled.
Unable to connect to ReadyNAS Photos share on 192.168.0.2
share=[hostname=192.168.0.2, share=Dekoh$], exit code=[32], error=[Warning: mapping 'guest' to 'guest,sec=none' ]
Thanks,
Kevin
