yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
jeoomkens
Jun 08, 2010Aspirant
Hello,
I currently own a ReadyNAS NVX for one moth now, so far I didn't run into any significant problems and I am happy the way this thing works. But now I've got a problem which I can't solve. I've read a view other posts on this topic but they didn't offer me any solution.
So what's my problem: I tried to install the add-on via System/Update/Local to my NVX but it says "invalid image" - I used to "latest" version of ReadyNAS Photo - ReadyNAS_Photos_2.2-x86.bin
I use RAIDiator 4.2.11 - and RAIDar 4.3.0
I rebooted the NVX several times, I also redownloaded the file... - Nothing works and it keeps saying "invalid image"
So maybe the image isn't compatibel with this version of RAIDiator? I don't know
Help!! Anyone?
J.
*** EDIT 28/06/2010***
I located the image in the media share of the readynas and then installed the image. That helped!
I now got a fully functioning readyNAS photos! :D
Help!! Anyone?
J.
