yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
glennvander
Aug 21, 2010Aspirant
Same issue here. In some browsers I get a blank screen but with Firefox you get a 500 Error with the following:
/2e8aeb98.a0f2398f.11cc0b206d95af30.8a/readynas/bookmark/2-3/3
Description:
java.lang.NoClassDefFoundError: com.sun.org.apache.xerces.internal.impl.dv.util.Base64
at com.pramati.bfly.cas.presence.api.facade.BflyURLConnection.decodeAddress(BflyURLConnection.java:700)
at com.pramati.bfly.cas.presence.api.facade.BflyURLConnection.getAddressFromCookie(BflyURLConnection.java:521)
at com.pramati.bfly.cas.presence.api.facade.BflyURLConnection.pipe(BflyURLConnection.java:486)
at com.pramati.bfly.cas.access.handlers.RemoteRequestHandler.handleRequest(RemoteRequestHandler.java:60)
at com.pramati.bfly.cas.access.filter.AccessFilter.doFilter(AccessFilter.java:67)
at com.pramati.web.servlet.core.PramatiFilterChainImpl.invokeTargetFilter(PramatiFilterChainImpl.java:243)
at com.pramati.web.servlet.core.PramatiFilterChainImpl.doFilter(PramatiFilterChainImpl.java:160)
at com.pramati.bfly.cas.login.api.auth.filters.AuthFilter.handleAuthenticatedRequest(AuthFilter.java:95)
at com.pramati.bfly.cas.login.api.auth.filters.AuthFilter.doFilter(AuthFilter.java:63)
at com.pramati.bfly.cas.util.i18n.LocaleFilter.doFilter(LocaleFilter.java:60)
at com.pramati.web.servlet.core.PramatiFilterChainImpl.startDoFilter(PramatiFilterChainImpl.java:120)
at com.pramati.web.interceptors.ServiceInterceptor.preProcess(ServiceInterceptor.java:114)
at com.pramati.web.interceptors.core.DefaultInterceptor.process(DefaultInterceptor.java:70)
at com.pramati.web.interceptors.core.InterceptorChainImpl.processNext(InterceptorChainImpl.java:48)
at com.pramati.web.interceptors.core.DefaultInterceptor.process(DefaultInterceptor.java:71)
at com.pramati.web.interceptors.core.DefaultProcessContainer.process(DefaultProcessContainer.java:97)
at com.pramati.web.core.WorkerThread.processConnection(WorkerThread.java:289)
at com.pramati.web.core.WorkerThread.processConnection(WorkerThread.java:263)
at com.pramati.web.core.WorkerThread.run(WorkerThread.java:129)
Description:
