yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
strange1
Oct 21, 2010Aspirant
I have ReadyNAS Ultra6 with RAIDiator 4.2.15, and have a problem with using ReadyNASPhotos (got 'Invalid credentials' when trying to login).
What i did:
- install ReadyNas_Photos_2.2-x86.bin addon
- install ReadyNASPhotosInstallerWithJava.exe (v1.1) on my WinXP.
- start application, register on www.readynasphotos.com as user strange and sucessfully Sign in (for that step i have enter my http proxy server address in application options). Application (opens in Firefox 3.6.10) discover my NAS on address 172.16.10.106, but I cant use it!
- see page http://localhost/readynas/template/index.jsp?pageId=settings
Host Name: ULTRA6
IP Address: 172.16.10.106
+ Requires authentication for media share
Username:
Password:
- fill Username and Password fileds with my account, that I added to NAS, ('media' share sucesfully opens with that login/password from my WinXP 172.16.10.2) But i've got 'Invalid credentials' in case of strange/guest or even empty username.
- i try to change 'media' options to read/write to everybody or only to strange - nothing helps
- then I try using ReadyNASPhotosInstaller-2.0.RC1WithBundledJava.exe, and get same result.
- I have read forum about that promlems, find many same issue, but no answer, thet helps me or any detailed problem description.
What steps should i try to make ReadyNAS Photos works ?
What i did:
Host Name: ULTRA6
Username:
Password:
