yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
saneca
Nov 30, 2010Aspirant
I have the same problem. I am using the Readynas NV+ in domain mode. I am logged into my pc using my active directory user name and password. I try to use the same username and password to connect to the readynas and it won't connect. "Unable to connect to ReadyNAS Photos share on 192.168.1.102. Is the ReadyNAS Photos service enabled ?" If I had a nickel for every time I've seen this lately! Anyone know how to connect to this thing. This would be a great service if it worked. I would love to share more photos than the 25Gb windows live space can hold and this seems to be a great way to do it. Thanks.
