yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
malarky
May 13, 2011Aspirant
Hi,
I'm having a problem that I can't find described on the forum.
I've got a Duo. I've installed the photos add-on. I've got an account at readynasphotos.com. I've installed the java software on my Ubuntu netbook and run it from /home/[user]/dekoh.sh.
It opens:
http://localhost:1025/readynas/template/index.jsp?pageId=settings
in Firefox 3.6.17. I login.
The 'discover' circle goes around a few times and it says 'No ReadyNAS device found'.
I can 'Add ReadyNAS host' at 10.1.1.200, with no credentials, or with credentials and it says 'invalid credentials'. I'm guessing that the invalid credentials are because it can't find the ReadyNAS, not because it has an issue with the credentials.
Any help on where I should start with this would be greatly appreciated.
It opens:
