yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
gponcho
Jun 15, 2011Aspirant
Hi I went to the Netgear website and downloaded the ReadyNas Photos II however everytime I try to install it under Update it does the first part (checking the file) then when I select Perform System update I get a error message "Invalid Checksum detected in the update file. Update aborted" can some one help?
