yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
drjane1
Jun 28, 2011Aspirant
hi there. I have a DUO. The RAIDar software and front end work fine, both disks synced and all is well. Then I tried to install ReadyNAS photos.....downloaded from the ReadyNAS photos site, double clicked and the installer started. After the progress bar reached about 95% it stopped and returned several Exception errors in Java. Install will not complete.
I tried to open the program but nothing happens, tried to uninstall from the Dekoh folder but it wont allow me to. Tried to download and install again but no joy. So I'm stuck with a useless partially installed program....any ideas bout how I can fix this issue?
