yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help. 1. If you are in User or Domain security mode, and you don't have "public" or "guest" access ...
kahuna
Mar 20, 2013Aspirant
OK, I just bought the ReadyNAS Duo v2. After spending hours trying to get invites to go out on photos, and after spending hours with support trying to get it to work,the support tech could not get Photos to send invites. He then told me it is a "known issue" and "many of these" don't work as they should with Photos II. Also, another "known issue": I can't upload files to readydrop on the web.
So, Netgear, here is my question: Do you think it is ethical to sell products that you actually know do not work? Here is the best part for me. I bought the unit from a store that is going to charge me a restocking fee. Thanks Netgear.
