srwFLA
Jun 16, 2025Aspirant
ReadyNas Pro Pioneer (RNDP600E-100NAS) No longer recognized by Raidar or DLNA Device
As of June 15, 2025, my Roku system (DLNA app), plus RAIDar 4.2.31, and simply using the admin URL are no longer seeing or decting my ReadyNAS. I am on MacOS 15.5 Sequoia. I last accessed the R...
srwFLA
Jun 17, 2025Aspirant
I found the software update for OS 6 v. 10.10 ARM the supported ReadyNAS models for this did not specifically list my unit which is RNDP600E-100NAS. Also the site would not provide an installation guide or manual when I clicked on the links. I received the 404 page error message for these.
Jun 17, 2025Guru - Experienced User
srwFLA wrote:I found the software update for OS 6 v. 10.10 ARM
As I mentioned above, you wouldn't be using the ARM firmware. If you want to get some idea about how OS-6 differs from 4.2.x, you can find the software manual here:
