srwFLA
Jun 16, 2025Aspirant
ReadyNas Pro Pioneer (RNDP600E-100NAS) No longer recognized by Raidar or DLNA Device
As of June 15, 2025, my Roku system (DLNA app), plus RAIDar 4.2.31, and simply using the admin URL are no longer seeing or decting my ReadyNAS. I am on MacOS 15.5 Sequoia. I last accessed the R...
Jun 17, 2025Guru - Experienced User
srwFLA wrote:Most of my files are backed up.
Your data is at risk, so the next step is to back up everything you care about. Do this before you reboot the NAS.
srwFLA wrote:I was unaware of the ability or necessity to run the NAS on OS 6.
Netgear doesn't support the conversion, but they don't support your NAS anymore anyway. It is not a necessity, just an option. It does require the disks to be reformatted, so you need a full backup of the files. You'd also need to upgrade the ram to 2-4 GB (easy to do, and in-expensive).
Note you'd use the X86 firmware, not the Arm firmware. We can give you instructions, but the main thing now is to figure out what is happening with your NAS.
Is there any indication of a problem on the LCD panel?
srwFLA wrote:I'm definitely getting timed out trying to access the admin page using my browser.
Is this with Safari? When was the last time you successfully accessed Frontview?
srwFLA
Jun 18, 2025Aspirant
I primarily use Safari, but I also tried to access the admin page with DuckDuckGo browser and both timed out. I also use Firefox on my Mac.
If Frontview is the admin page that RAIDar takes you to, its been at least 6 months since I last accessed that.
Duly noted on the X86 vs. ARM firmware update. Thanks!
The LCD panel is not indicating any problems, and it appears that all six drives are on.
I will look up and figure out what type of RAM to get to upgrade to 4MB and Sandshark recommends upgrading the processor too. Perhaps I will do the processor upgrade after stabilizing the current situation,
I will get everything backed up before I start doing all these steps, and please do share instructions on the X86 firmware update.
Thanks for your continued assistance!
