coricidin12
Feb 06, 2013Aspirant
ReadyNas Remote Can't see shares
I have a ReadyNas Pro 6 running the most current firmware and the most current version of the Remote plugin. Initially, it was working fine and I could access my shares remotely. Now, I can connect to the NAS and I can even access the remote admin and the readydrop folder, but no shares from the NAS show up when I try to browse it. When I chose Open Folder-->NAS from the Remote menu, it just brings up an explorer window of My Documents (local) which is the parent folder for the readydrop folder. I'm on a laptop running windows 7 x64.
Now on my wife's comp, a Mac, I can run readynas remote and access the shares no problem, using the same user settings and everything, so it's not a permissions issue. Does anyone know why I can't get the shares to show up on my windows machine?
- mdgm-ntgrNETGEAR Employee RetiredI agree. A firewall issue does sounds like a likely cause for this.
- dobbsyAspirantThanks for the reply, im looking into it now in settings, Another weird issue is im transferring files via FTP as I cant access the open folder view and if I close ready nas remote down it disconnects the FTP as well,,
- mdgm-ntgrNETGEAR Employee RetiredWhat do you mean by close readynas remote down? Turn ReadyNAS Remote off in the Dashboard (web admin interface of the NAS)?
- dobbsyAspirantWhat I did was open readnas remote up and log in as admin, enable ftp and put the details into filezilla, and started to download a couple of videos to my laptop,
I then closed down readynas remote on the laptop it disconnected me from filezilla as well, I did a couple of reboots but filezilla cant connect to my nas if readynas remote isnt running.
