Mills
Nov 27, 2011Aspirant
ReadyNAS Remote Duo V2 installation
I recently purchased a ReadyNAS Duo v2 and when I go to the add on tab to install readynas remote and click "get" a message comes up saying installation in progress, please wait for confirmation. I have waited over a day and it still says this. I have also done a factory reset and the message is still coming up. Please let me know if there is any additional information I can provide to solve this problem.
- calvinhoppesAspirantI am a little disappointed not to find a hint for a real solution. I don't want to loose all the time spend to understand my Duo V2.
Unfortunately I had to reboot the NAS and after the reboot procedure the ReadyNAS addons aren't working anymore:
- Photo II is not showing the port number 8086 in the configuration area (and thus is not working) and
- ReadyNAS remote is showing an error message: https://my-readynas.ip.
"The ReadyNSAS Remote addon is disabled, please enable it before launching this management page."
How is it possible to enable the addons? They are installed and at least Remote is showing a green dot.
Please help!? - mdgm-ntgrNETGEAR Employee Retiredcalvinhoppes please contact NetGear tech support (http://www.readynas.com/support).
- wullzaAspirantHi
are you able to confirm then, that I cannot access my DuoV2 from my iPad? I have the Remote Access installed, and I have been able to find the device on my iPad, however I consistently receive the error, "Please check that your FTP service on your ReadyNAS is running" etc etc
The remote application walkthrough does not appear to have been prepared in the format of the new version of the ReadyNas v2 software, which does not have any "ftp" settings (that I can find)
thanks - Snipe3000AspirantAnything yet for the android?
- mdgm-ntgrNETGEAR Employee RetiredSure.
chirpa wrote:
To use Remote on iPhone/Android (via FTP) on Duo v2, try this add-on: http://www.readynas.com/download/addons ... rm_1.1.bin (enables the FTP service on the Remote network interface)
Future Remote or iPhone will have the option to use CIFS instead of FTP. Not sure when that will go through the App Store approval process. - PerchlorateAspirantI read these threads and would appreciate any help. I have a new NV v2 and am trying to connect via Android. I was able to get the NV v2 set up and the Remote working on our computers, but not on an Android phone. Following this thread,
I downloaded the file and installed it into the NV v2. It rebooted. However, for the last 24 hours I get the message "Device is Offline. Please Wait" on the Dashboard. Any suggestions? Thank you in advance for your help. - Papypat30200AspirantAll is OK with my Readynas duo V2 except that I can't access it by REMOTE with my Android phone GALAXY S
The application on the phone seem to function,I can connect with a good user ID, it give the name of my nas in Remote tab but don't respond and show a "221 Bye" message.
I have well installed the 2 adds on on the NAS : REMOTE and IPHONE RMOTE and the 2 light are OK ( green)
Any idea what I missed ?? - hidetoraAspirant
calvinhoppes wrote: I am a little disappointed not to find a hint for a real solution. I don't want to loose all the time spend to understand my Duo V2.
Please help!?
I too have the same problem with my DUO v2 getting the '...please enable...' error message, I telephone technical support and in a rather embarrassed tone I was told that it is a know issue but Netgear don’t have the solution yet and no idea when it will be solved. Not the best of responses but at least I know its not me doing something wrong now, just wish Netgear would sort the problem out ASAP. Just thought anyone else reading this thread with this problem might like to know. - andershlAspirant
Papypat30200 wrote: All is OK with my Readynas duo V2 except that I can't access it by REMOTE with my Android phone GALAXY S
I experience exactly the same on my Motorola Defy. Have two DUOs, at different locations, they work perfectly well from computers at different locations with different userids. From the 'droid I DO see both in the display, right arrows shown, ready to open the share lists. Whenever trying to do so, however, I simply get "221 Goodbye" after a second or so.
