TOUSASDOM
Sep 19, 2015Follower
ReadyNAS Replicate Connect error code: -50
Sorry for my bad translation. Hello. for a while I am getting an error code [2015-09-19 11:04:56] [Error] Unable to connect to nas-F6-53-BA_ [2015-09-19 11:04:56] [Error] Connect error code: -50 W...
BrianL2
Sep 19, 2015NETGEAR Employee Retired
Hi TOUSASDOM,
This error code -50 pertains to a problem with communication between your NAS devices via ReadyNAS Replicate. Kindly check the ff. and see if it fixes the issue that you encountered.
- Check the Internet connectivity and service connectivity on both sides.
- For OS6 series NAS. ReadyNAS Remote should be enabled on both sides.
- For restrictive firewalls and more complex networks, consider setting up port forwarding.
- Remove Replicate user binding and re-add the NASes to the Replicate account. Then, recreate the backups. Use the “resume from…” option to avoid having to send all of the data again.
Kind regards,
BrianL
NETGEAR Community Team
- chalvorsonjrMar 02, 2016Aspirant
HI, I am having the same issue, except of these differences:
1. Source device is "ReadyNAS NVX Business Edition - RNDX4410" running firmware: RAIDiator 4.2.27 (Replicate Version: 1.2.0 build R1)
2. Destination device (device I am trying to backup to): "ReadyNAS 314" running firmware: 6.2.2 (Replicate Version: 1.3.0 build R2)
Important note: both devices are on the same LAN and on the same subnet (one is 192.168.0.110 and other is 192.168.0.150)
My error is: "Connect error code: -51"
- JennCMar 02, 2016NETGEAR Employee Retired
Hello chalvorsonjr,
See ReadyNAS: Replicate Troubleshooting article, it has the list of error codes and their possible solutions.
Welcome to the community!
JennC,
Thanks for the quick response!
I did do the connectivity troubleshoting steps as I mentioned. I am going to try to upgrade the firmware on the Destionation device running the 6.2.2 firmware to see if that helps.
Also, please note I did the following troubleshooting steps asyou recommeded in this post:
1. I validate the ReadyNAS Remote is enabled on both sides
2. I unbinded and rebinded both NAS devices to the replicate account
