troypiggo1's avatar
Jun 02, 2011
ReadyNAS Ultra 4 and apt-get
Please tell me I haven't just made a huge mistake and bought the wrong RN. I went for the Ultra 4 because I liked most of its features - RAM, 2 ethernet ports etc. But just picked it up and starting to set up and reading this website, it appears the apt-get addon is only for SPARC processors? Doesn't work on the INTEL ones like this Ultra 4? Had a bit of a search around and couldn't find posts here on it, but looking at the download for the apt-get addon there's only a SPARC binary. :(
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    APT is pre-installed on the x86 (Intel) devices (e.g. NVX, Ultra, Pro), that's why there's no add-on. Install the EnableRootSSH add-on and you'll be able to SSH in as 'root' and do an
    apt-get update && apt-get install build-essential
  • *phew* Thanks so much for the quick reply!
    Haven't been able to check, because it's doing a huge resync of 2TB drive and I can't reboot it for the SSH access install. Will have to wait til tomorrow now.
    Very relieved, though. Thanks.
    mdgm-ntgr
    You're welcome.
    Just be sure not to do an "apt-get upgrade" as this will break the Frontview web-interface and probably other things as well. Where possible I would recommend using community add-ons.
  • Ok, thanks for the tip. I'm a long time Ubuntu user, and do use "apt-get upgrade" a fair bit, along with "unattended-upgrades" etc.
    So I'm intending to install a few servers like postfix, amavisd-new, clamav, dovecot, dnsmasq, iptables, squid, spamassassin, apache etc. It's only for a family home server, not many users. Do I have to keep them up to date manually? Or should I configure apt to not upgrade certain packages so that Frontview doesn't break? If so, what packages? If not, what do you recommend I do? I didn't see addons for all of those services, and the ones I did see didn't appear to be the latest versions.
    mdgm-ntgr
    I would install the things you want manually. The list of things that shouldn't be upgraded may change from one firmware version to another.
    A key advantage of addons is that they generally can be easily removed.
  • Was just trying to get git running on my readynas ultra 4. But encounters this error.
    Would really appreciate any help
    NAS:~# apt-get update
    Get:1 http://archive.debian.org etch Release.gpg
    Get:2 http://www.readynas.com 4.2.17/ Release.gpg
    Get:3 http://archive.debian.org etch Release
    Get:4 http://www.readynas.com 4.2.17/ Release
    Ign http://archive.debian.org etch Release
    Get:5 http://archive.debian.org etch/main Packages
    Ign http://www.readynas.com 4.2.17/ Release
    Get:6 http://www.readynas.com 4.2.17/ Packages
    99% [5 Packages gzip 0]
    gzip: stdin: not in gzip format
    Err http://archive.debian.org etch/main Packages
    Sub-process gzip returned an error code (1)
    99% [6 Packages gzip 0]
    Err http://www.readynas.com 4.2.17/ Packages
    Fetched 21.6kB in 20s (1078B/s)
    Failed to fetch http://archive.debian.org/debian/dists/etch/main/binary-i386/Packages.gz Sub-process gzip returned an error code (1)
    Failed to fetch http://www.readynas.com/packages/4.2.17/Packages.gz Sub-process gzip returned an error code (1)
    Reading package lists... Done
    W: GPG error: http://archive.debian.org etch Release: The following signatures were invalid: NODATA 1 NODATA 2
    W: GPG error: http://www.readynas.com 4.2.17/ Release: The following signatures were invalid: NODATA 1 NODATA 2
    W: Couldn't stat source package list http://www.readynas.com 4.2.17/ Packages (/var/lib/apt/lists/www.readynas.com_packages_4.2.17_Packages) - stat (2 No such file or directory)
    W: Couldn't stat source package list http://archive.debian.org etch/main Packages (/var/lib/apt/lists/archive.debian.org_debian_dists_etch_main_binary-i386_Packages) - stat (2 No such file or directory)
    W: You may want to run apt-get update to correct these problems
    E: Some index files failed to download, they have been ignored, or old ones used instead.
ProSupport for Business
