kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
ecar
May 29, 2011Aspirant
+1
However, I found a workaround. After the "upgrade" (...), I downloaded and installed the legacy Leaf Network Adapter Software from here:
http://www.leafnetworks.net/download.html
Not ideal, but RNR should work until (hopefully) Netgear provides us with a proper solution...
