kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
pmignault
May 29, 2011Aspirant
UscholdM wrote: Summary: if loading the leaf network adapter software brings back the Internet and gets RNR working again, isn't this an an ideal solution?
Details: Does downloading Leaf Network Adapter Software bring back the Internet connection? If RNR works, and if the Internet connection works, does this not effectively solve the problem? I'm not sure how this is not an ideal solution for those who upgraded and lost their connection. The other solutions offered bring back the Internet but not RNR.
Michael
ecar wrote: +1
However, I found a workaround. After the "upgrade" (...), I downloaded and installed the legacy Leaf Network Adapter Software from here:
http://www.leafnetworks.net/download.html
Not ideal, but RNR should work until (hopefully) Netgear provides us with a proper solution...
Yes I confirm that this temporary solution works for the moment.
Running Windows 7 x64
