kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
citat3962
May 31, 2011Aspirant
mdgm wrote:
As for testing new hard drives, that requires a great deal of time and expense to do properly. NetGear doesn't add drives to the list on a gut feeling, they test them thoroughly.
I only quoted you because the "awww shucks" attitude about this blunder needs to stop. This is a prosumer product and I expect professional support of it's functions.
I only bring up the HCL because it seems they DO spend a great deal of time and expense to do it properly. They don't seem to give the same weight to properly testing their RNR updates. If they had even tried installing it on a win7 64bit system they would know it breaks the network connection completely every time without fail. If they're so meticulous about the HCL why are they so lax on testing this RNR update?
