kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
kingbadger
Jun 05, 2011Aspirant
Is anyone from Netgear monitoring this?
OK, so the updated download no longer forces the disabling upgrade but the Leaf Nework adapter appears to be blocking all traffic from my ReadyNas to the internet....therefore disabling Remote.
I cannot even begin to configure the add on since the ReadyNas can't see the internet through my router, so even though I have an account and am online with ReadyNas Remote it cant connect so I cant add myself to the ReadyNas as a user.
I see a lot of Windows 7 issues arount the forums, especially for those running X86 like me. None of the downloads or config suggestions helps. I dont have a static IP or anything unusual - but either my router or an adapter config issue is blocking access.
My Leaf Networks Adapter status shows No Network Access for both IPv4 and IPv6 connectivity. (The gateway field is already blank so that one doesn't work...)
Do I need to get into port forwarding on my router?
