kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
mdgm-ntgr
Jun 05, 2011NETGEAR Employee Retired
kingbadger, this sounds like a separate issue.
Did you try configuring the add-on before you installed ReadyNAS Remote? If you have email alerts configured on the NAS do these get sent? If you go to System > Update > Remote in Frontview are you able to check for firmware updates?
What version of RAIDiator and what version of ReadyNAS Remote on the ReadyNAS?
