kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
kingbadger
Jun 05, 2011Aspirant
mdgm, thanks -
Yes, I can check for firmware updates "The system is already running the latest firmware. Click Perform System Update if you wish to proceed with the update anyway." (so I see your point - to do this the ReadyNas must be getting to the internet)
But I cant configure the add on - I get the message "ReadyNAS Remote could not connect to the ReadyNAS server, please check your internet connection and DNS settings. If the ReadyNAS is behind an HTTP proxy, please make sure you have entered correct proxy server settings" when I try to "Manage ReadyNas Remote".
But I am not using a proxy server. My internet connection is straigtforward DHCP - dynamic with DNS provided automatically by my ISP
Radiator is 4.1.7, ReadyNas Remote is 1.6.5.16 (both are latest updates) the add on version on the NAS is 1.0.9.51
